whizzkid Posted July 30, 2011 Posted July 30, 2011 Hi Everyone well after much delay I have now receieved my zp3 properly and all parts are now at my house I am not a fire engineer, This is not a trade use install, it never will be I am not after codes or manuals but would like to ask. I do not have the codes, but have found the maintainence code by starting at 0000 and working upto 9999, am i right in assuming that all codes must lay between that number. I have the commissioning key and the front panel key and the cabinet key I have the 2 loop panel with printer and remote repeater card. I am about to buy a copy of the planner software but please can i also ask what is difference between setup level and level 4 under the zp3 also I see the panel reports some loop devices as L.G.U or L.something.U please can you advise what this might be The panel is an ex initial panel branded as shurrock fire as3. many thanks whizz p.s. please can i ask that unlike last time i dont get lots of messages advising me to call an engineer and not to play with a life safety system. I bought this to play with thanks once again
garsec Posted August 9, 2011 Posted August 9, 2011 you will not be able to access level 4 without the codes, as an engineer i cannot access level 4 it is usually only ziton agents that can access this menu, all that is in level 4 is options to change codes, and reset fault and fire counTers. Employed by an NSI GOLD company Any comments or views i have are my own, and do not represent that of my employer or clients.
