S=1 Lost. Fault Can't Delete
spannermad
Hi guys,
I am new to your forum, please be gentle, if my etticate is not up to scratch :)
I have a Risco wisdom wireless alarm system. Had a few problems with faults in the past of which the original installation enineer sorted. Now it is out of warrenty, i pretty much have to sort any problems out myself, of which to date have all gone sucsessfully, Until now.
I have a fault that does not seem to want to to be deleted..
I can go into the fault menu sellect Y to disable the fault. It is always listed in the menu, when ever you go into it. The system will not let me set unless i override the fault.
the fault is S1= Lost, i assumed it was the battery in one of the sensors, so have changed all of these..
Any ideas or help would be most gratefully recieved.
Regards Shaun K.
no you don't, get a professional in.
but that will keep costing money :(
Thats the way the world works, everyone works, everyone gets paid for work, everyone pays for work
It's lost the bell. Get a repeater fitted and it should sort the problem. Also change the batteries in the bell.
Thankyou for the kind advice, You have been a great help, It appears that it was low on batteries in the bell box. I will now now for in the future :)
Regards Shaun K.
