actsafe Posted August 15, 2011 Posted August 15, 2011 I have an elderly Scantronic 9300 panel that came with the house. It was working OK but came with no manuals. The system was turned off recently and the battery allowed to discharge fully while i was doing some other electrical work. I repowered the system, it came back on however it had lost the preprogrammed user code and defaulted to 1234. The panel is working in that i can change the user code, perform a bell test and perform a walk test. It is set up with an entry zone and a single alarm zone. All detection is by reed switch buried in the door frames somewhere. As i say these all function correctly on the walk test. The panel shows the following leds: power, day and zone 1 while unset. When trying to set, the panel gives an extended beep as the 4th digit of the alarm code is entered and refuses to set. I had assumed the fact that the zone 1 led was lit meant the system thought the detector was active and refused to arm. This is not the case all doors are shut, and when entering the walk test the zone 1 light disappears until the door is opened as it should. zone 2 is shorted with a wire link. I read somewhere that these old panels don't like being powered up and jumping into full alarm - Have i blown its brains out? Is it time for a new panel? Any suggestions gratefully received Thanks Andrew
modernjim Posted August 15, 2011 Posted August 15, 2011 Try turning off power then disc.the stand by batterythen power up.Worth a try
actsafe Posted August 15, 2011 Author Posted August 15, 2011 Hi. Thanks for that. Have already tried that several times, comes back up the same each time regards Andrew
