Driller Posted August 29, 2011 Posted August 29, 2011 I'm getting a new stone wall put up in front of the house and I'm concerned about the local scrotes having a field day with graffiti after it's finished. The idea is to put one or two cams looking along the wall for piece of mind's sake. They will be pole mounted, either from the ground or on a 90° arm fixed to the house side of the wall. The wall itself is curved so no trouble seeing along the outside even if the cams are on the inside IYSWIM. What have folk used in this situation to good effect? External domes (already have SVD4600s), armoured bullet type (easier to pole mount?)or classic box? as ever
MrHappy Posted August 29, 2011 Posted August 29, 2011 photo or drawing of the (proposed) wall would help greatly with pisstaking advice Mr Veritas God
Driller Posted August 29, 2011 Author Posted August 29, 2011 Hey, you know I'm always here for you when you need a good laugh I'll post up some photos/diagram this evening, .
Cyberprog Posted August 29, 2011 Posted August 29, 2011 They'll graffiti it whether there are cameras or not. The only way you can combat it is by coating it in anti-graffiti paint, or by getting it painted with a graffiti mural - but even those don't last that long in some areas. Unless you have someone watching the cameras 24/7 for the scrotes and they'll go and chase em off, you're on a hiding to nothing, as they'll just wear hoodies and masks for the fumes anyway!
Driller Posted August 29, 2011 Author Posted August 29, 2011 Here's a rough diagram. The wall is about 25M long at this point and will be 2M high. Cameras will be placed in the two corners. Here's the neighbours wall for reference: ETA for Cyberprog: No chance of painting this wall with anything I'm afraid, it's natural stone.
Cyberprog Posted August 29, 2011 Posted August 29, 2011 Similar in construction & height, i.e. half and half brick and railing? If so, that sort of surface is generally not that likely to be graffiti'd. I'd try and sit the cameras out a bit more as you may find you'll get a blindspot in the middle.
Driller Posted August 29, 2011 Author Posted August 29, 2011 Thanks for the advice. Ours was originally like the above but sadly someone decided to redo it in breeze blocks years ago. The new one will be natural stone, 2 meters high, no railings. Any thoughts on camera type/spec as in my first post above?
norman Posted August 29, 2011 Posted August 29, 2011 Do you live on a roundabout? Nothing is foolproof to a sufficiently talented fool.
Cyberprog Posted August 29, 2011 Posted August 29, 2011 Hrm, well natural stone will be a good bit more resistant to graffiti - they tend to like a flatter surface and the make up of a natural stone wall tends to prevent this. That said, you are probably flogging a dead horse in terms of prevention, if they're going to spray it, they'll spray it, regardless of cameras. I'd probably err towards cameras on poles observing from high up, with a vandal proof dome up there. But I wouldn't be expecting anything more than being able to see when it happened! What's the light levels like at night? That'll dictate a bit towards the camera choice, if you have a street light or other lighting of your own you can probably look at high resolution b/w or colour, but if you have little light then you might be better off with vandal proof IR surface mount domes.
MrHappy Posted August 29, 2011 Posted August 29, 2011 That street looks continental? Do the locals write there opinion of the mad Englishman on the wall or something? Mr Veritas God
