Scantronic 9752 Kp Missing
andyprutica
hi
i have installed about 7 scantronic 9752 with expanders in 7 diferent locations
all of them came randomly with the fault kp01 missing exp01 missing
the only way to reseted was to disconnect the battery and power
we changed the panels with replacemnts send by scantronic but same fauls came up after a while
we have installed many other scantronic panels but this 7 cose us such a greef
scantronic technicles said that are site conditions and install spike suppresors witch we did but with no luck
das anyone know what can be the problem?
thank you andy
thank you for the quick replay
they are cabled star and the distance is unde 50m
we have changed the cable with shilded alarm cable as the technicle recomanded
but the same problem
the power is from the panel but we used diferent power for pirs from aux
the most pirs we have are 7 on one system
regardes andy
we did separate power for pirs from aux output and doubled the cores for data
scantronic recon that 50m is ok as long the data is doubled
the amp is not exceding 300mA
