Poe Cameras
whistle
We are well into a very large IP CCTV job we are fitting a mix of internal and external Axis POE cameras.
So far i have fitted around 70 but still having problems focusing them. I have been using a small midspan PSU and my laptop to focus the cameras with and extension lead, this is far from ideal on a large site.
How do you lot do this ??
Note: if we try to focus using phones with one of us using a PC on site or the servers its **** as there is a small amout latency.
We have another 110 cameras to fit so a better solution to this would help, some of the ones coming up are statics on towers so the laptop method is out of the question.
LOL, i thaught i had one, my laptop :)
Hi whistle. much cheaper than a laptop ..... came out last year by axis but now available from most cctv suppliers. well worth it for your size of job . around £200
http://www.adata.co.uk/files/a95fe4cd-f162-4bf2-9c99-9ea900a862ca/TESTER%20007.pdf
or you can pay £500 from norbain. both the same units.
https://www.buyfromnorbain.com/Documents/ocw/0524690~Document~0.pdf
What about the POE...
hi the monitor has POE just plug a camera into it focus then if needed set ip and protocols. the monitor is also auto detect and find camera.
Do they not have analogue out for focusing? I fitted a load of sony ip domes and they had a local out
Any idea on price Alpat? thats just what i am after...
no :(
