Sms Centre Number: Galaxy G3
jezf
The centre number I have been using for a while appears to have been switched off. Constant engaged tone. Is there an alternative please?
Was that the O2 one ending 0480? Vodafone was working on 07785499993. Beware though, I was having problems with it sending out four or five repeat SMS messages before the panel would get an ack from the TAP MODEM. Could end up expensive! Better to go down the Ethernet path ;)
Any SMS service that uses a dial up MODEM to free TAP service is going to be unreliable. If you can use a GSM modem direct to SMS message center, then this will be much more reliable, but is still open ended.
I've been working on an alternative self monitoring IP service for the Galaxy range of panels equipped with Ethernet modules. My experience is that SMS is okay for informational type messages, but priority - actionable events are better served by a voice based service. I use e-mail and SMS for all events and include voice for actionable type events.
Regards,
Have you tried the sms function on the hkc
Yeah uses Bt servers doesn't it? The line has to be enabled to send a text message IIRC, more like sending a landline a text message.
Wasn't aware of a panel that uses bt's landline SMS service. Any pointers to docs on this? Is it 10.5p per message too?
Regards,
yes thats how it works. But i think sms is s### so havnt even tested it as i have no intention of using it.
My thoughts exactly, but try telling management and salesmen
Yes it was the O2 one and the new one works, thank you.
I would like to get a GSM modem to text me on activation of the alarm. This should bypass the reliance on the free SMS message centres. But I really like the present setup in that the G3 will text me with exactly which zone has been triggered with the zone description. Will this work with a GSM modem and can anyone recommend one that will do this too?
