ACCENTA 8 MINI SYSTEM G3
Guest alarm eng
Guest alarm eng
insalled one in my house 6 week ago went to arm it today and theres a tamper light flashing. On the keypad cover it says if tamper light flashers read oprating maunal but theres nothing a bout a flasing tamper light in the operating manual
or the eng manual can anyone help?
Page 28 - Faults:
"c. If a tamper, PA or 24Hr fire fault is
present on the system, it will go to a
lock out condition (showing the
appropriate indication). The keypad will
not produce any audible responses
and the system will not operate until
the fault has been found and rectified.
d. The most common cause of a zone not
responding to detection is incorrect
wiring. Normally closed detectors must
be wired together in a series loop
before connecting into the appropriate
ZONE terminals. Tampers are series
wired in the same manner.
e. Where a permanent zone fault is
showing and the loop resistance is
found to be in order, the most probable
cause is a short circuit between the
zone wiring and the tamper wiring.
When measured with a multimeter the
series resistance between the zone
and tamper wiring should be infinitely
high.
f. If totally lost as to the cause of a fault,
remove ALL wiring from the Board.
Refit the 4-links and test the system.
Never fit links to any positions other
than those marked on the Board.
g. Before testing or replacing any fuses,
ALL power must be removed. Fuses
which fail continually are almost
certainly the result of a short circuit or
low resistance across the 13V supply
or external siren (bell box) supply
(terminal D).
Whenever working close to the mains
supply or connector, you should
exercise extreme caution.
Always isolate the mains supply before
removing the control panel covers.
Where normally open and closed
detectors are being used these must
be wired to a zone in the manner
shown."
Also check that you have the service timer switched off.
Colin
Guest alarm eng
checked all that and the service timer is not set but the system sets normal :unsure:
Guest Guest
If the system is functioning correctly other than the fact that this tamper light is on, then the fault is with the service timer go into the options and switch off or change the indication settings(how many sets/unsets till it shows up)
