bfreeman Posted September 26, 2011 Posted September 26, 2011 Hi I have a Galaxy 16 panel. The isnurance company is insisting that I set it at night. Please could someone remind me how to do that and also which zones to omit (or do I just keep only exit door active and switch off all PIRs)? Previously they have waived this condition as I have small children and I don't want them to set the alarm off when they come down early in the morning. Ideally I am going to have to get the children to switch it off when they come dowm. Can it be switched off with a key-fob? Thanks Ben
MrHappy Posted September 26, 2011 Posted September 26, 2011 part set =code then b key, your zones may not be programmed to allow you to omit, as to which ones requires omiting I've no idea! if you have keypad with a prox reader you can use prox tokens, check rkp to see if they put a prox sticker on or your written spec for the system Mr Veritas God
james.wilson Posted September 28, 2011 Posted September 28, 2011 The 16 does not support prox but you could add a standalone prox reader and connect it to a keyswitch zone. Part set as above but there are 3 part sets so usually it would be #### B 1 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
