everton2005 Posted October 3, 2011 Posted October 3, 2011 need a bit of advice my alarm suddenly started going off always triggered by zone 3 so i changed the pir and last night it was triggered by zone 2 the living room any advice is most welcome
PeterJames Posted October 3, 2011 Posted October 3, 2011 When did you last have it serviced or changed the battery?
everton2005 Posted October 4, 2011 Author Posted October 4, 2011 the battery was changed 6 months ago serviced 6 months as well
everton2005 Posted October 4, 2011 Author Posted October 4, 2011 so the system is knackered then i am going to change zone 2 pir and see if that sorts it out
everton2005 Posted October 6, 2011 Author Posted October 6, 2011 also should i set the alarm with the battery disconnected to see if that sorts the problem out
fozzies Posted October 6, 2011 Posted October 6, 2011 Sounds to me that u need an engineer. the pulsar panel must be 20 years old by now. too many things could cause the problems you are having, the only one of which a non engineer will resolve being pets. I suppose you could try fitting a mains filter to the panel, but with that panel you will probably be throwing money away. get yourself a professional in this case imo
PeterJames Posted October 6, 2011 Posted October 6, 2011 also should i set the alarm with the battery disconnected to see if that sorts the problem out That wouldnt prove anything? A disconnected battery is the same as dodgy battery
james.wilson Posted October 13, 2011 Posted October 13, 2011 if you moved the sensor from circuit 3 to circuit 2 then id suggest you have a duff sensor securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
