Lucky Boy 66 Posted October 7, 2011 Posted October 7, 2011 Hi, Just after a bit of advise, should be simple.? I have a Sterling 10 system all working fine, i have the manuals, codes, instructions etc etc. I have decided to upgrade the bell box to a back lit Deltabelle, that i have purchased of the net. The guy i bought it from suggested that i completely power down the whole system including battery back up then replace box otherwise i may short out the system, Question is, will i need to completely reprogramme the panel and PIRS when i bring it back to life, or will it still have the info stored? If i do , i had better get reading the instruction manual before i take it apart. Any advise would be triffic Thanks in advanced
Lucky Boy 66 Posted October 7, 2011 Author Posted October 7, 2011 Brilliant , Thanks very much for your swift reply
PeterJames Posted October 7, 2011 Posted October 7, 2011 You won't need to reprogramme it. Unless its broke
Lucky Boy 66 Posted October 7, 2011 Author Posted October 7, 2011 Nope, the whole system works OK, just want to change the bell, so as long as i wire it correctly.............bingo !
fozzies Posted October 7, 2011 Posted October 7, 2011 You realise your existing bell box will go off when you de power it? Better get some ear protection....
PeterJames Posted October 8, 2011 Posted October 8, 2011 Nope, the whole system works OK, just want to change the bell, so as long as i wire it correctly.............bingo ! I meant unless the Non volitile memory is broke, then of course you will have to reprogram it
Lucky Boy 66 Posted November 6, 2011 Author Posted November 6, 2011 You were not wrong ! Managed to change over ok, but the original bell box didn't go without a fight ! Ear defenders needed and a pair of wire cutter to finall kill the old one ! New box all good and glowing well.
