steq184 Posted October 10, 2011 Posted October 10, 2011 Hi I want to connect 2 Exodus OH/4W smoke detectors to my Accenta G4 Mini control panel. The connections on the detector are: Latch input. 12V 0V No connection (use for loop through if required) A & B Alarm relay normally closed on alarm. How should this be connected? Any help greatly appreciated. Steve
modernjim Posted October 10, 2011 Posted October 10, 2011 12v as norm then wire the A B to circuit .Not sure you have to program circuit as fire or circuit 7or8 can only be set for fire
steq184 Posted October 10, 2011 Author Posted October 10, 2011 Just to clarify A & B to the circuit 7 or 8 but where to connect 12v? Thankyou for the help Guessing it goes to the +13v terminal right??
james.wilson Posted October 12, 2011 Posted October 12, 2011 yes connect it to the 13v and 0v terminals for power securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
steq184 Posted October 15, 2011 Author Posted October 15, 2011 ........so how do I link the 2 detectors together, I guess I run wire from one detector to the other and wire in the same as the first one but am not sure.......do I connect both loop throughs on the detectors together?
fozzies Posted October 15, 2011 Posted October 15, 2011 You will need to connect the power in parallel and the alarm in series
steq184 Posted October 15, 2011 Author Posted October 15, 2011 Bit confused now, can you clarify that you mean from panel to 1st detector wire in power and A&B to alarm, link A&B from 1st detector to 2nd detector, wire power from panel to 2nd detector? Guess that's what you mean.....just not sure what you meant by parallel or series. Thankyou
fozzies Posted October 15, 2011 Posted October 15, 2011 http://en.m.wikipedia.org/wiki/Series_and_parallel_circuits thats probably the easiest way to explain
