Sterling 10 Adding Zones Problem
Lucky Boy 66
I have added another door contact to my sterling 10. however when I do the walk test and go to set the alarm,it says that the door is open ???
I have set the zone as no5 (next on the board) and have set as "immediate" in the programme memory.
I have done a continuity test on the cable and the cable and mag contact are working fine, it just says that it's open when I connect to system.
Any help/advise would be great.. Thanks
Sorry, do you mean connect the two contacts together as if you are shorting out the circuit?
I will have to try and get back to you... Not sure as the empty zones were all "omitted" previously
To measure for cross voltage put your meter onto dc volts range, one probe onto earth then the other probe to firstly 0v then +12v. please post the two results here
Triffic, meters just broken-gonna have to wait till tomorrow for the voltage !
however i did cross connect and the fault has cleared in the panel ???
Will post further info tomorrow
Looks like a panel fault/programming error then. but do get the meter on in before replacing panel, induced voltages can cause Major faults that are indestinguishable from panel faults.post your readings when u get them
Sorted, i have taken off the tamper and the fault cleared!
Now used different pair of wires for the tamper and all good
Thanks again guys for your help! Currently working my way through the circuit diagram, installing sound bombs,speakers etc etc, so I may post more issues as they arise
Who ever gets in uninvited will leave Deaf !!!
