securealarmsolutions Posted November 7, 2011 Posted November 7, 2011 Hi all, I'm looking to add audio to existing cameras on an installation on a farm. The existing cabling feeding these cameras is cat5, can the audio be done over this cabling?? The audio in connections on the back of the dvr are BNC type, does this mean i can use baluns either end (with phono to bnc convertor at microphone end) and bobs your uncle??!! Also i will need sound to the existing monitor, the audio out connection on the dvr is also BNC type, will i be able to just add an audio cable between dvr and monitor with a phono to bnc convertor?? Also do you know of any good adjustable microphones to use?? Hope this explains all. -Steve
miaren Posted November 7, 2011 Posted November 7, 2011 Hi Steve, I've used this microphone with success. You might get intereference over a long length of cat5 - don't know, not tested it. nor the baluns. http://cpc.farnell.c...e-bb45-00001001 You'll need a 12V supply to the microphone, and you can just use the correct BNC convertor, or make a lead up. For testing the DVR ouput, I've used a std Internal Speaker (held close to the ear), so you'll need a monitor with volume control or a set of PC speakers. Fairly simple really.. Good Luck.
securealarmsolutions Posted November 7, 2011 Author Posted November 7, 2011 Hi Miaren, Thats the microphone i was looking at, agree that it will hopefully do the job. The cat5 run is approx 70 metres in length. I've got a seperate 12v supply at the camera for the microphone already so this ain't a problem. for the reply.
