harvey123 Posted November 22, 2011 Posted November 22, 2011 Hi, A newbie looking for some help ) I have a PIR in the hallway (Zone 2) setup as an Entry Route. The control keypad is also in the hallway. I have a bedroom off the hallway. At night, I would like to Part Set (Level C) and slip into the bedroom. However, the panel complains that Zone 2 is 'open'. How do I solve this problem ? Any help appreciated. If I've not explained myself well enough, then please let me know what other info I can provide. ,
antinode Posted November 26, 2011 Posted November 26, 2011 You need to change the level C entry route operation to become Final Exit and level C exit mode to "silent". These are options 71 and 72. I'm not sure if it will stop the intermittent "BEEEEP" that you get if you trigger a detector while the system is silent setting, but the way you have it set up at the moment will cause a full alarm when you try to unset the system. Trade Member
fozzies Posted November 26, 2011 Posted November 26, 2011 Putting a zone onto entry route should solve the beeeeep problem. even if its a FE :s
