PAS Posted November 25, 2011 Posted November 25, 2011 I am about to install two systems, one in a house one in a workshop, but want to be able to connect them both to a single speech dialler like a SD1. If I power the dialler from one panel I assume I will need to also bring a positive or negative common from the other as well (along with the negative trigger). Both control panels are the same. Texecom Veritas Excel
Belfastengineer Posted November 25, 2011 Posted November 25, 2011 You will need a relay being trigged from the remote panel then link the neg from host panel into n/o on relay to fire differnt channel on the SD1 so you can define which panel has activated.
fozzies Posted November 25, 2011 Posted November 25, 2011 I would have thought you could just link the two panels0v together? Cant think of any reason not to? ( unless youve got rfi on one panel)
magpye Posted November 25, 2011 Posted November 25, 2011 Don't use an SD1, it does not have an NVM, losing power = reprogramme, use an SD2 or similar. Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
breff Posted November 25, 2011 Posted November 25, 2011 Just link the Ov together, the sd1 doesnt have a NVM but the sd1+ does The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
magpye Posted November 26, 2011 Posted November 26, 2011 On 25/11/2011 at 22:48, breff said: Just link the Ov together, the sd1 doesnt have a NVM but the sd1+ does that's the one I meant Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
sixwheeledbeast Posted November 26, 2011 Posted November 26, 2011 Yes linking the 0V together should be fine. You should use a different input on the dialler for each panel tho.
PAS Posted November 26, 2011 Author Posted November 26, 2011 Thanks guys yes it would be the SD1+ as loosing the memory is a real pain (been there!)
PAS Posted December 18, 2011 Author Posted December 18, 2011 Could'nt get it to work with joining the 0v lines but we did have a suspicion of mixed up wires as the runs back to the dialler was with Cat 5 using one pair and cameras on the other, we ended up having three panels plus a fire alarm panel into the one dialler so for simplicity and it being 8pm we went with two "handy little relay" boards on the remote systems an the normal neg trigger on the one beside the speech dialer, all worked ok. Thanks for help and suggestions
MrHappy Posted December 18, 2011 Posted December 18, 2011 On 18/12/2011 at 12:51, PAS said: as the runs back to the dialler was with Cat 5 using one pair and cameras on the other, we ended up having three panels plus a fire alarm panel into the one dialler anybody else thinking...... Yeehaw ? Mr Veritas God
