petrolhead Posted November 26, 2011 Posted November 26, 2011 We've been asked to quote for an unusual detector on a job, customer wants 30 combined heat/smoke alarms with an internal sounder and relay contact output, must run off either 12 or 24v. I've found plenty of multisensors with relay contacts but none with a sounder built in. Any suggestions?
Lwillis Posted December 1, 2011 Posted December 1, 2011 does he require a panel or stand alone detectors? rafiki do a twinflex system i think the multipoint detectors have relay outputs, they definatley have sounders built in tho. does he require a panel or stand alone detectors? rafiki do a twinflex system i think the multipoint detectors have relay outputs, they definatley have sounders built in tho. does he require a panel or stand alone detectors? rafiki do a twinflex system i think the multipoint detectors have relay outputs, they definatley have sounders built in tho. does he require a panel or stand alone detectors? rafiki do a twinflex system i think the multipoint detectors have relay outputs, they definatley have sounders built in tho.
petrolhead Posted December 2, 2011 Author Posted December 2, 2011 Standalone ones, its to connect into the smoke detector inputs on a warden call system in a sheltered housing complex. The system has 12 and 24v supplies for connected peripherals and the room unit is looking for a no or nc sontacts with an eol resistor
norman Posted January 25, 2013 Posted January 25, 2013 Olé Nothing is foolproof to a sufficiently talented fool.
Ronnie Posted January 25, 2013 Posted January 25, 2013 so let me get this right, the customer wants 4 fire alarm systems right?
