Eurosec Cp8L Lcd
Kerry12151
I need to be able to part set my alarm and turn off certain zones as I have cat. I have read the manual and worked out how to do this the only problem is I dont know which area correcspond with each zone. How do I find this out when I do the test I can see that it says front door or dining room but how do I find out which Zone this relates to?
You need the engineer code to go into system programming then zone descriptors.
Also part set programming is in the engineers functions. Might bpe good to get an installer out to go through the system withbyou and programme what you need.
