Newbie Help
djsizzle
hello,
I would like clarification on if it is possible to have an addressable control panel with a conventional smoke detector, an organization with an ionization smoke detector menvier mid 710 wants to switch to the addressable control panel. is this a possibility?
Interface off the loop or radial in the controls can surrport conventional devices.
When you say menveir it normally better to use only with menvier controls
