dmc Posted December 8, 2011 Posted December 8, 2011 Hello, I've recently installed an Accenta G4 without problems - When I powered down removing both mains and battery the external siren went off. I expected this. My question is what does one do if a PIR requires replacement, that is, replace it with a live control panel or power down and annoy the neighbors for 20 minutes? Or am I missing a trick? Thanks David
modernjim Posted December 8, 2011 Posted December 8, 2011 Put the panel in engineering if you have the code then conect new pir just be careful not to short the 12v
Rulland Posted December 8, 2011 Posted December 8, 2011 Dis power to the detector that your working on.
Scotmod Posted December 8, 2011 Posted December 8, 2011 Surely if you installed it you'll know how to stick it in engineer?
fozzies Posted December 8, 2011 Posted December 8, 2011 Modernjim is spot on. into engineering, the replace, being careful with the wire that connects to +12v (dont short it to another wire)
itesecurity Posted December 8, 2011 Posted December 8, 2011 Remove fuse from spur unit, put it into engineers, remove the endstation cover, remove auxilary fuse that feeds your PIR's (or remove the positive feeds for your pir's from the terminal), replace PIR and then do the above in reverse order.
dmc Posted December 9, 2011 Author Posted December 9, 2011 Thanks itesecurity for your helpful advice
