morgan306 Posted December 9, 2011 Posted December 9, 2011 Hello chaps,I've taken out one of these little units from a site,and would like to get it going. Unfortunately I haven't got the IP addy that the unit was assigned before I removed it. I've got the manual from Dallmeier,but does anyone know of a program that would be able to find out the units current IP? I've tried removing the button cell battery on the pcb to revert it to default but no luck.
Belfastengineer Posted December 9, 2011 Posted December 9, 2011 Have you tried a scanner lilke angry ip?
morgan306 Posted December 9, 2011 Author Posted December 9, 2011 No I haven't Kevin,I'll give it a google now and have a go. Thank you for your reply.
Belfastengineer Posted December 9, 2011 Posted December 9, 2011 Give it a go and try the more common ranges and you should get it. Also check dhcp isnt enabled don't know if it supports it or not. Good luck
fozzies Posted December 9, 2011 Posted December 9, 2011 Colasoft mac scanner scans ips faster than angry ip, will save u some time
