itesecurity Posted January 17, 2013 Posted January 17, 2013 OK, guys, Hope you are ready for this... Bought the Defender GSM with a bit of fear and trembling, but do you know what - it's actually pretty good and does what it says on the box. To be fair, some of the chinese made components look, how should I say this.... cheap. but thinking about it, the system is er... cheap. I stuck a virgin payg sim in with direct debit so it' won't run out. connected up a strobe siren, some pirs, some door contacts, a smoke alarm, a gas alarm and a keypad. It took a couple of hours. Another hour to program in the numbers and a message and bobs your uncle - works like a dream. The property is a holiday home so now the Defender will tell me whenever the power goes off, if there is a breakin, if there is a fire and it won't worry if the power is cut or if the phonelines are cut cos it's pretty much a stand alone system. So for a couple of hundred pounds i got me a good system that has worked efficiently, at least for the last year with only one false alarm ( someone forgot to disarm before entering! ) Now, you guys who earn your living by installing more expensive products are probably going to be pretty miffed by this but I read your extremely biased reviews above and thought that someone who actually had the kit should let you know how it performed. Right? and before you ask, I don't have any connection with any of the companies that sell these. If I did, I wouldn't mention the absolutely diabolical instructions translated literally from the Chinese and the fiasco of trying to get the sim card into a slot that if you missed would drop down into the control box and be lost for ever. But besides these problems I still believe it a good bit of kit. It wont inform you of a fire though. Because it will be the cause of the fire.
Oxo Posted January 17, 2013 Posted January 17, 2013 Wait until next door install a wireless door bell.
Ronnie Posted January 18, 2013 Posted January 18, 2013 hang on guys, he has a point. i know for one i'm "Now, you guys who earn your living by installing more expensive products are probably going to be pretty miffed by this". i don't think so.
MrHappy Posted January 18, 2013 Posted January 18, 2013 i don't think so. you hard hearted *******... Mr Veritas God
