Installed Coving - Pet Tolarant Pir Facing Downwards
HI
We have a cat and ADT installed our system about a year ago. We set the alarm almost daily and had no false alarms for a year.
Today, I fitted some coving in a bedroom. I removed the PIR, put the coving in and re-fitted it. The coving is small meaning the existing screw hole was still visible/accessible a few cm below the bottom of the coving. However, the PIR is now pointing a bit downwards - all the other PIRs in the house are flush to the wall.
The PIR certainly would appear to pick up movement around the bedroom but should I cut the coving with a knife (its the lightweight polymer stuff) ? Perhaps if I leave it as is then the cat could set it off? Visually it looks ok - its just making about a 20 degree angle with the wall.
Any advice gratefully received.
Put it back as it was. PIR's shouldn't be tilted down.
It's more likely to false alarm, especially if it's a pet friendly one.
The best option would be to get the installer to relocate, extend the wiring below the cove.
20 degree's is like 2 inches to your missus, in the world of detectors
LOL
He means it useless
Hey Ho, Lets Go
  • 1 month later...
  • 2 months later...
