Menvier Ts690R Beeps Regularly
jmac862
Hello all
I've got a bit of a problem with my TS690R panel in that it sounds its 'normal' triple beep three times at intervals of 30 minutes for long periods then goes quiet for an hour or two then repeats the process.
It doesn't matter if the the system is set or not it does it regardless.
Nothing appears on the display. I've gone through the config and checked, all seems well. It passes a walk-through check and reacts normally to the front door opening
It's just those beeping beeps at all hours of the morning spoiling my beauty sleep
Anyone have any idea the problem might be?
THere are two PIRs, two magnetic door detectors and five vipers all separate devices
Thanks
Jmac
Give the log a read, user code, ent ent, 9, then use A key to go backwards, I'm sure there will be something logged.
Checked the log but nothing in there apart from what I've done, certainly nothing repeatedly
Ive been in the engineer programs to do all the investigation but didn't do anything called eng reset
the battery could be something as I don't believe its been changed. Device batteries have been changed when they warned low...
Might it be a failing panel?
Jmac
Just swap all detection batteries, and control battery (for decent ones)
Cheaper than a new panel, you dont change your engine if it has a slight misfire. Start with the basics and go from there ;)
