Guest danieford Posted August 12, 2004 Posted August 12, 2004 New electricity meter fitted yesterday. alarm has locked us out. key pad no longer working . zones 1 and 2 are red tamper light is red power light is red. how do i reset it all?
Guest dale Posted August 12, 2004 Posted August 12, 2004 Did the bell box go off when the power was off? If so then its likely your battery has gone, go buy a new battery. Power down the system, install new battery (this will restore battery power to system) then put cover back on and restore mains. If you are lucky the programming wont be lost, otherwise you will need an engineer to come re-program the system.
Guest danieford Posted August 12, 2004 Posted August 12, 2004 an engineer is probably best bet. where do i start trying to find one?
Guest dale Posted August 12, 2004 Posted August 12, 2004 Post your area on here and we will see if we can recomend any in your area.
Guest danieford Posted August 12, 2004 Posted August 12, 2004 Oldham - OL9 postcode Need someone who knows Optima xm system and is reasonably cheap.
Guest gibson Posted August 12, 2004 Posted August 12, 2004 Oldham - OL9 postcodeNeed someone who knows Optima xm system and is reasonably cheap. 19980[/snapback] Detection And Security Services 0161 287 5425
