So, Bs 8243:2010
9651
Cut off may, confirmed HUD's, affecting anyone yet? We are still installing to existing at the mo.
Just skimming through, noticed you can now use internal prox, and PTS to set (again)! Whats the score with external prox now? Same as before? Swipe, then terminate,or would this now not conform?
i'm not thinking that you couldn't before??
completion or arming needs to be a 2 stage process. So IMO you can arm externally but you need pts or something to complete the set.
but its close to the dual running cut off now so probably good to discuss
Yes but it sounded like you couldn't use a PTS before which you could (can)..
well you can/could what makes you think you couldnt?
post number 1 "noticed you can now use internal prox, and PTS to set (again)!" the again in brackets gave me the impression 9651 thought it wasn't allowed..
using an internal prox reader (part of keypad) and then operating a final circuit I would assume is the most common method used at the moment? This is definately classed as a 2 stage process right?
IMO final door set is poor. ie it causes too many issues.
What kind of issues? Every single system we have is on final door set and I don't recall this being an issue at any point? I think the alternatives to final door set will push the price to high (on most jobs).
