Veritas Excel Outputs?
Avotronics
Hi,
Tried to find this info but google is not my friend :(
Does the Excel have outputs that can be attached to a relay for example?
If so, where on earth is the spec sheet to tell me what ratings to adhere to....
Furthermore, if it does and can, can they be programmed to activate the relay on set and unset?
Thanks
Danny
There is one normal output (sw1),this may be usable as set/unset reading the gumf, but there is no dedicated prog for it as set/unset,I would have to try and see!.
There are also communicator outputs,one of which is set/unset-my best bet would be try that-it is configurable as pos or neg by the looks.
Either way a relay would be required depending on what you are trying to achieve.
Can't be much more help than that without actually hooking one up and trying-but that's much the same with all panels tbh until you've done it once and fathomed it out.
Yes, best to use a relay.
"Spec sheet" = Installation Manual.
Veritas Excel has one programmable output.
This can only be programmed as the following
SET POSITIVE
LATCHING SENSOR RESET
LATCHING AUTO RESET
TAMPER
MAINS FAIL
SET POSITIVE WITH RESET
WALK TEST
ENTRY/EXIT
This is protected by a 1A Fuse. Only Positive Applied.
It also has 8 comms outputs fixed to do the following in order of pin 1-8.
FIRE
PA
UNCONFIRMED
SET
ABORT
ZONE LOCKOUT
DURESS
CONFIRMED
They can be inverted but only all pins together not separately.
Each output can sink or drive 100ma max.
They can be set to Latched or not. (Latched = active until disarmed and Reset is pressed)
You will be able to trigger a relay with Pin 4 to change state on Set/Unset.
SET POSITIVE
LATCHING AUTO RESET
TAMPER
MAINS FAIL
WALK TEST
ENTRY/EXIT
FIRE
PA
UNCONFIRMED
SET
ABORT
ZONE LOCKOUT
DURESS
CONFIRMED
That great thanks. Just seen that in the install manual.
I haven't got the excel yet and was trying to decide on the right panel for the job while not going overboard.
I'm still debating the excel, prem 24/48.
Excel sounds like it'll do what I need, just a set/unset output.
Thanks
  • 2 weeks later...
Does exit mode begin as soon as the panel is set/armed or when the panel is set/armed and the entry/exit zone is activated?
Ta
Danny
Okay thx for your help, one last thing... you seem to know these panels, so;
Does the panel pulse the comms/SW outputs or is it a continuous current that gets sunk on state change?
I'm assuming it pulses from what I read, but I haven't wired up yet otherwise I would have checked myself.
By t-relay do you mean latching relay?
Danny
