Avotronics Posted February 20, 2012 Author Posted February 20, 2012 Im guessing t relay - tranasistorised relay Yes, very likely. The panel only outputs a small current, might need to ramp that up to drive some relay coils.
Avotronics Posted February 20, 2012 Author Posted February 20, 2012 So what about outputs, do they pulse or send a continuous current?... Anyone?
breff Posted February 21, 2012 Posted February 21, 2012 Continuous and will drive a relay no problem The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Avotronics Posted February 21, 2012 Author Posted February 21, 2012 Continuous and will drive a relay no problem So in the case of sw+ set as entry/exit the relay would simply be energised or not? Well that's easy than expected. Actually solid state relays are a good option for these alarm panels, just a bit more expensive.
