Security Kit Recommendation
RAMBO
Can you guys tell me what you normally install in and around peoples homes now days.
1) What NVR / DVR units?
2) What CCTV Software?
3) What IR External Floods?
4) What Internal and external IR Cameras?
5) What Wifi solutions, if any?
6) Power supplies / Poe injectors?
Remember im talking home equipment, not super high end expensive corporate stuff (although im aware some home kit is very expensive). I'm looking to install 8 - 16 cameras tops and maybe a couple with audio; so if you can recommend some kit that you've tried and tested that would be wonderful. I need your suggestions fairly sharpish though as I've been told by the local athority to take down my current security mesures on the perimeter of my property, it seems that my motion detecting M60E3, plus speare and claymore traps havent gone down very well with the postman, so I need to be a bit more conventional and reduce my level of security to mere CCTV equipment.
Ayway I hope you can help with your suggestions.
Regards
RAMBO
Our own unit, Artnix or DM depending on the requirements
Depends on number 1
Bosch / Derwent
A secware pro unit if low end. If higher end wouldnt use them, ie would use a proper camera and emitter
Anything we do neywork wise is either netgear pro or cisco for switches AP's etc. Routers are draytek
PSU, elmdene, dont use injectors use cisco or netgear poe switches
