Pyronix Vocaliser Dialer Flt & Ack
davethebuilder
Could anyone explain the "FLT" and "ACK" terninal configuration on the Pyronix vocaliser dialer please
I intend to retro fit the dialer to a system and use the relay outputs (of the vocaliser A1 and B1 )for other automation but still retain the remote reset of alarm ability.
Thanks for the reply, :) That would make sense ,
the terminals are on the same strip of inputs as the 4 triggers 1, 2 , 3 ,4
so FauLT could be a signal uotput to use if the dialer fails to dial ,due to a FAULT
and acknowlege is a signal output to confirm someone has ACKnoleged the call ,and in theory could be used to auto re-set the alarm panel remotely.
