Von Posted February 11, 2012 Posted February 11, 2012 Hi all, I have moved to house that has a Guardall Rascal Super fitted. I need to decommission as I understand its quite old. Im wondering if I start taking off the wall, or opening control panel and PIR's if my alarm will go if even though its not set? If so will entering my code disable the alarm? Thanks Von
Rulland Posted February 11, 2012 Posted February 11, 2012 User code should shut it up-but may not reset it.
james.wilson Posted February 13, 2012 Posted February 13, 2012 your code will silence alarms but will not disable it. Be a poor system if it could. It is old yes. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
psycho_49 Posted February 15, 2012 Posted February 15, 2012 Also if you decommision the panel you will have to remove the battery from the bell box as this will run on its own for a while when you down power the alarm panel..
