Accord XPC
Guest Dude
Hi Folks!
Help! I have just moved into a new house which has an //.National Installer.// Accord XPC installed. It used to be connected to a monitoring station, cos of this the previous owners didn't have an external siren put on (only got an internal siren).
//.National Installer.// are quoting some ridiculous price to have an external siren installed. Therefore, i rung a local Alarm firm and they said that they could fit me an external siren (different make) for a fraction of the cost, however, as these alarms are protected by 'engineers codes' they would also have install a new keypad.
Can anyone please help? Has anyone got the engineers codes (s)? Any advice would be much appreciated.
Thanks in anticipation
Dude
Changing Codes 8
The Accord xpC can be programmed with up to eight User Codes. User 1 is assigned as
the Master User. The master user code is neccessary to programme new User Codes for
the system.
Note: User eight may be assigned as Duress via group 6 option 4.
Reprogramming Your Code
To reprogramme your code, enter it at a keypad, select the codes option by pressing 8, select your user number and enter the new code.
The Master User Code is code 1, the Engineer Code is code 0.
Note: The engineer must change his code from day mode not programme mode.
Example: To change the master user code (Code 1) to 5678:
They're either trying to swindle you out of some extra money or they haven't got a clue what the hell they're doing. Either way i'd go somewhere else.
