Avotronics Posted February 16, 2012 Share Posted February 16, 2012 Hi, If an alarm is set and the main entry door is opened breaking the door contact, the alarm beeps waiting for a code before the alarm sounds. What 'state' is the alarm in during that waiting/timeout period? I'm just trying not fathom all the terms related to programming outputs and wondered about the above. Thanks Danny Link to comment Share on other sites More sharing options...
Rulland Posted February 16, 2012 Share Posted February 16, 2012 Entry time Link to comment Share on other sites More sharing options...
psycho_49 Posted February 16, 2012 Share Posted February 16, 2012 But do not stray from the entry route or it will be alarm... Link to comment Share on other sites More sharing options...
PeterJames Posted February 16, 2012 Share Posted February 16, 2012 Hi, If an alarm is set and the main entry door is opened breaking the door contact, the alarm beeps waiting for a code before the alarm sounds. What 'state' is the alarm in during that waiting/timeout period? I'm just trying not fathom all the terms related to programming outputs and wondered about the above. Thanks Danny Its still set/armed until you either enter the code or swipe your fob then it becomes unset/disarmed. but if you do nothing and allow the entry time to expire the system will go into alarm Link to comment Share on other sites More sharing options...
Avotronics Posted February 16, 2012 Author Share Posted February 16, 2012 I see thanks. So if the state is still set/armed, then presumably there is nothing triggered on outputs to make use of at that very moment? Link to comment Share on other sites More sharing options...
PeterJames Posted February 16, 2012 Share Posted February 16, 2012 I see thanks. So if the state is still set/armed, then presumably there is nothing triggered on outputs to make use of at that very moment? That depends on the panel my panel at home switches on courtesy lights Link to comment Share on other sites More sharing options...
Avotronics Posted February 16, 2012 Author Share Posted February 16, 2012 That depends on the panel my panel at home switches on courtesy lights I see. Thanks for the info. Link to comment Share on other sites More sharing options...
Avotronics Posted February 16, 2012 Author Share Posted February 16, 2012 Screw it, looks like the veritas excel has no such options. Knew I should have got the premier :-/ Link to comment Share on other sites More sharing options...
james.wilson Posted February 16, 2012 Share Posted February 16, 2012 higher end panel can give an output of that type as required securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
PeterJames Posted February 16, 2012 Share Posted February 16, 2012 Screw it, looks like the veritas excel has no such options. Knew I should have got the premier :-/ You get what you pay for, the reason something is cheaper is usually because it has less features and options. A basic system is fine if all you need it for is to protect your property. You can get the output you need using T relays and some jiggery pokery but it would be easier to use a panle that has the feature in the first place Link to comment Share on other sites More sharing options...
