Rcbo Vs Protected Circuit
Avotronics
You beat me to it, I was gonna answer my own question.
If cost ain't an issue, but space is, RCBO is ideal.
Also for the important point you make....
In terms of protection, no different.
U can pick up a fully loaded consumer unit with split rcbs for less than 70 squids, cost cant come into it at that price
but space is,
Rcbo's take the same width as an mcb-but are usually longer and take up more room with the additional wiring directly attached to themselves, to fully load a CU with them is more challenging!.
I was thinking more on my own requirements, I can lose two rcds and two mcb and gain two rcbos. Must be better in terms of space, no?
But yes, I agree that if you are keeping current rcds then it may be worse.
As Fozzies then imo,get fully loaded 17th board for substantially less than buying rcbo's-no real reason for going separates unless circuits they supply are critical,guaranteed they aren't!.
You can also put stuff on the non rcd side of a split board as long as the requirements of BS7671-17th edition are adhered to.
True, but then you could do that anyway, could you not!
| isolator | non rcd mcb | rcbo | rcbo | rcd | mcb | etc
I do have a need for splitting circuits as its for my workshop and I've a lot of test equipment, etc.
But I agree with the cost factor, business seller on eBay has 40+ mk 16 way split load fully loaded con units and I could have won one today for £58. That had two rcds as well.
Have to bid I think.
Depends what its for I guess - if its for a house, and you have a freezer on one circuit and a N-E fault on another both fed from the same RCD, and you can't find the fault... :-(
