Brian c Posted August 12, 2004 Author Posted August 12, 2004 ill look it up at the library! :0) If you don't know......ask.
Guest Posted August 12, 2004 Posted August 12, 2004 why dont you get one off the company you work for £22 not alot of cash to help you out..
bellman Posted August 12, 2004 Posted August 12, 2004 They may have to get it in for you, so be prepaired to wait for them to find a copy. Here in Sheffield, I had to travel to the central library in town to get it as the local one didn't and wouldn't get it for me. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Brian c Posted August 12, 2004 Author Posted August 12, 2004 mmm im gonna have to hit and hope as im doing it on saturday thanks for your help though, i might try the library if i get the chance! If you don't know......ask.
jb-eye Posted August 13, 2004 Posted August 13, 2004 Did you know:- White Spirit doesn't get bitumen off your hands. : Try sugar & butter Customers!
Brian c Posted August 15, 2004 Author Posted August 15, 2004 Try sugar & butter lol thanks back to the original topic. I have installed the system now but the front door was a little akward. I've installed a roller shutter contact, but i've had to pack out the magnet with wood. So, i bolted a piece of wood to the door and screwed the magnet to it. What i need to know is...Will this conform to current regs. also i was going to fit 2 x 360 d/t's to warehouse area but only fixings are the framework (apex shaped). i would have to build a little frame to hold the sensor...would that conform to regs? If you don't know......ask.
Brian c Posted August 15, 2004 Author Posted August 15, 2004 ah they're not that bad...what about the regs...any ideas? If you don't know......ask.
Guest Posted August 15, 2004 Posted August 15, 2004 ps.as long as its a good fix it dont matter,i often pack r-s-c's up a couple of mm to allow water to run underneath,stops rotting..get no problems with them..
Brian c Posted August 15, 2004 Author Posted August 15, 2004 he he he it's more than a couple of mm it's a very good fix, but it's 3"x2" :0) If you don't know......ask.
