Nexus 8 Alarm System
Viv
Hi all, I recently moved ino a house with a Nexus 8 alarm installed. Ican set the alarm on my way out but I do not know how to set it when I'm inside the house.
I do not know anything about alarms. This is the first housevim living in that has alarm installed. I'm afraid to do something that will trigger it falsely but I want to use it at night as a safety measure.
Will be glad for suggestions that can help. There is no manual available.
Thank you.
Wendy.
As you have moved into a property that already has a working alarm system, I expect it has been programmed to do what you are asking.
There are 2x Part Set options with your Nexus 8 >
Part Set 1. Enter your code - press 1 > I would expect this option to be the one you need.
Part Set 2. Enter your code - press 2
Normally Part Set will isolate the upstairs, as you want.
Assuming it is an audible only system, turn it on as part Set 1 & go upstairs & have a good walk around, if it doesn't go off, job done.
Good luck, let us know if this works.
