Little Bit Of Advice Required For Garage Door Contact.
stubs
Hi,
I have bought a couple of heavy duty roller shutter contacts to install on my garage door at home (similar to this: http://www.diy-alarms.co.uk/catalog/product_info.php?products_id=108&osCsid=0dca2faafe650bf9927976d609abbd23)
Whilst I'm aware I need to join them to the 8 core alarm cable that I've run using a tamper junction box, I'd like to ask a couple of questions regarding standard practise for installing these type of contacts;
What it the best way to attach the magnet to the garage door? Pop rivets, or nut & rounded head bolt? Or something else?
Should I use p-clips screwed to the floor/wall to secure the armoured cable before it meets the junction box? Or is there a better product to use? I will cut the conduit down a bit, but there will still be some that needs to be held in place.
Thanks in advance for any replies, I hope the sarcasm can be kept to a minimum :teehee:
Any decent nut/bolt will do-coated though and I usually put an extra 'locking' nut on to prevent vibration loosening.
'p' clips are fine-again coated metal type are my choice.
See no sarcasm in sight!.
We use self drilling screws (big ones) with grommets - don't have any problems this way but must admit I would prefer if we used nut and bolt.
we use nuts and bolts and p clips. Used to use those screws rfs but over the years we found some worked loose.
You're not using a big enough impact driver then. :D
Ali tube - elmdene tube jb - p clips - nuts w/nylon and bolts.
Ronnie you rough barsteward :lol: We only use them for metal clad fixing.
To be fair, we don't do that many RSC and I agree self drillers are a bit rough - they are the big ones though..
