anyone using rain x as standard on cctv systems?
Just for domes or all cams?
Taken from rain x website...
Can it be used on transparent plastics
Generally no. The increasing variety of various coatings applied to plastics makes it impossible to pre-test for compatibility under all conditions, and users should satisfy themselves by treating an area outside the normal area of vision. Please note that constant, repetitive use should be avoided due to the possible formation of stress cracking, especially on clear, curved sections
We've witnessed this first hand on a takeover. On-site maintenance had reported hairline cracks on the PTZ dome covers. When questioned turns out they where using rain x several times a year.
Cool, thanks for that.
Would you on metro housings though.
  • 3 months later...
Some (box) CCTV Camera housings are equipped with wipers. I wonder if there are any for Dome Cameras . Anyone knows ?..
--------- CCTV Aetherica - Surveillance & Security Solutions ---------
If youre still after something to clean the dome plastics,
Give this a try, (Meguiars Plast R-X Plastic)
We have used it on a few dome plastics and it works a treat,
I keep a bottle in the van for servicing,
!! Remember !! Test a small area first, I aint gonna be responsible for fooked covers
Little bit of info about the product I posted earlier;
This easy-to-use, rich gel formula quickly restores optical clarity to both rigid and flexible clear plastics.
Cutting-edge advancements in Meguiar’s® exclusive Microscopic Diminishing Abrasive™ Technology (MDAT)
remove light oxidation, chemical degradation, surface contamination, stains and light surface scratches with ease.
In addition, because the microscopic diminishing abrasives breakdown as you use them, PlastRX Clear
Plastic Cleaner & Polish is safe on plastic rear windows on convertible tops, aircraft windows, motorcycle fairings,
face shields, headlights and taillights, instrument panels, all clear plastic boat surfaces and aquariums.
Meguiar's PlastX also contains highly water-resistant polymers. These specialized hi-tech polymers provide long
lasting durable protection to keep your clear plastics clear and beautiful longer.
