Can You Recommend A Good Qualty Surface Mount Magnetic Door Contact?
As above can you recomend me a good one that is available in the public domain?
I fitted one to the garage when i re-installed my alarm, It's fubared already as the magnetic switch inside sticks.
The one i installed was from tlc direct, perhaps a better quality one this time!
cheers guys
Dave
The reed is sticking? Hit it with the back end of a screwdriver to free it up. Normally caused by not using the door enough
Nope, replace it in case it sticks again when you need it.
Tis true Norm, but many a time ive tapped my own contacts,and they have lasted a good twelve months before next tap, so imo a good temp solution. I failed to state that in my reply, my bad :s
Yea that was my first thought, gave it a crack with the back of a screwdriver which did unstick it, unfortunately after that is was permantly open!! disconected on the panel untill I replace it. Cheap Sh*te.
Thanks for the tip on Elmdene, with give it a google.
