johnnyd Posted May 7, 2012 Posted May 7, 2012 Hi All I am having a trouble, if i connect a hardwired IR detector to zone 29, it works on the home setting, ie motion doesn't set the alarm off, however in away mode, after entering the property and passing through the detector, the alarm is set off, zone 29 is definately set to interior-follow, does anyone have any ideas as to why ? Many Thanks JohnnyD
petrolhead Posted May 10, 2012 Posted May 10, 2012 do you have both the 2k2 resistors installed properly? what is showing in the event log?
