agentoso Posted May 16, 2012 Share Posted May 16, 2012 Firstly I would like to say hello to all. Nice forum plenty of helpful advice. About ready to purchase my alarm system, not quite decided the make, still researching. It will be a wired system; the extension is almost completed, so while the house is in a bit of a mess I will run the wiring, and then decorate. Now that brings me on to my question. If I wired 2 doors in series and to the same zone, will both be exit/entrance doors? I can’t see why not, but because I want it that way the answer is bound to be no. Thanks for reading and I hope you can point me in the right direction. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/ Share on other sites More sharing options...
MrHappy Posted May 16, 2012 Share Posted May 16, 2012 mostly likely "yes", but depends on the controls Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284316 Share on other sites More sharing options...
agentoso Posted May 16, 2012 Author Share Posted May 16, 2012 mostly likely "yes", but depends on the controls Thanks for the reply Mr Happy, but er which controls are we talking about? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284317 Share on other sites More sharing options...
MrHappy Posted May 16, 2012 Share Posted May 16, 2012 Yours, maybe you'd like to share with the group what product you have? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284318 Share on other sites More sharing options...
agentoso Posted May 16, 2012 Author Share Posted May 16, 2012 Oh I see. Well still in the research stage but Honeywell g2 flex 12 is high on the list. Texecom Premier 24 is in the running or Accenta Gen4 is low on the list. Basically I am finding it hard to wire everything on 8 zones, just need a few more for peace of mind. Do not want to go wireless. I know technology has moved on, but I am a firm believer in testing and not taking the word of the manufacturer. So how do you test if the anti jamming is working on a wireless setup? If I could do this it would make my life easier with wireless. Anyway plan is windows and doors contacts, pir’s in all rooms and glass break detectors downstairs. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284319 Share on other sites More sharing options...
sixwheeledbeast Posted May 16, 2012 Share Posted May 16, 2012 Dont series zones just because you only have * zones on the panel! They make zone expanders for a reason. AFAIR, Premier 24 can have an onboard expander so 16 zones in the panel. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284331 Share on other sites More sharing options...
agentoso Posted May 16, 2012 Author Share Posted May 16, 2012 Thanks for that sixwheeledbeast. That is why the premier is on my list. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284347 Share on other sites More sharing options...
Anusoflannigan Posted May 22, 2012 Share Posted May 22, 2012 You can also use the zones in the keypads on a premier 24 and just program them as zone 9 and 10 etc.. even easier if you have a keypad near to your doors. Its no problem wiring a couple of door contacts in series, until something goes wrong and then you have to work out which one is faulty/causing issues. Wireless is far easier but the door contacts are usually bulky and won't fit easily to pvc door edges and of course you need to change batteries from time to time.. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-284523 Share on other sites More sharing options...
Graham Preston Posted June 22, 2012 Share Posted June 22, 2012 Are you working 4 wire or EOL? It will determine how they are wired in series. Galaxy would use 3 resistors, 2 res nc and 1 for the EOL Where as others would need the switch res across both reeds plus the EOL Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-285223 Share on other sites More sharing options...
james.wilson Posted June 22, 2012 Share Posted June 22, 2012 i would keep to 1 device per circuit. Expand your panel to suit. So whatever you use just add the relevant expanders to give you the number of circuits you require securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/32961-two-doors-in-series/#findComment-285241 Share on other sites More sharing options...
