Zemme Posted May 16, 2012 Posted May 16, 2012 Hi All Hope you are all well. I hope i am posting my query on the correct thread. I would dearly appreciate any advice that is provided for my query. I recently had a Honeywell Galaxy G2-20 installed by my uncle. He has only installed a couple of these Honeywell alarms previously, however he is stumped on a certain issue. My setup is as below. 1 X Honeywell Keyprox MK7 CP-038 Keypad (Address 0, Downstairs) 1 X Honeywell Keyprox MK7 CP-038 Keypad (Address 1, Downstairs) 1 x Honeywell RF Portal (Address 4) The issue that i currently face is that the only functioning keypad is downstairs. From an overall perspective, the alarm functions fine with the keypad installed downstairs. I can set & unset the alarm fine. The issue is that the upstairs keypad and the rf portal do not function when connected to the power supply. The upstairs keypad led is rapidly flashing with a green led and flashes with many stars, eg. ***************************************. The keypad was beeping when installed, however the esc key was pressed to silence the audible keypad beeps. The rf portal is not connecting correctly via the data line. I have come to the conclusion that the communication link has not been wired up correctly. The current setup has the A & B from the keypads & rf portal connecting directly on to the A & B data bus on the G2-20 panel. It is not daisy chained. Are my assumptions correct? Also the last connection (rf portal) does not have a 680ohm resistor connected between the A & B. Should the setup be like this? 1. Alarm Panel Data Bus "A" -> Keyprox Keypad Downstairs Data Link "A" -> Keyprox Keypad Upstairs Data Link "A" ->RF Portal Data Link "A". 2. Alarm Panel Data Bus "B" -> Keyprox Keypad Downstairs Data Link "B" -> Keyprox Keypad Upstairs Data Link "B" ->RF Portal Data Link "B". 3. RF Portal Data Link "A" -> RF Portal Data Link "B" (Looped Using A 680ohm Resistor). I appreciate your time to reply. Best Regards Zemme
james.wilson Posted May 16, 2012 Posted May 16, 2012 All your a conections should connect to a and all b to b. Have you exited engineer mode after adding the devices so the panel can find them? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
magpye Posted May 16, 2012 Posted May 16, 2012 A line of *********s on the RKP = No Communication on A B Line, possibly faulty PCB Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
fozzies Posted May 16, 2012 Posted May 16, 2012 A line of *********s on the RKP = No Communication on A B Line, possibly faulty PCB Or lack of resistor
james.wilson Posted May 16, 2012 Posted May 16, 2012 Doubt its the resistor Also it will not communicate with the panel till the panel is aware its there. A power cycle or exiting engineers will instruct the panel to look for new devices added to the system securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
fozzies Posted May 16, 2012 Posted May 16, 2012 Only added that through personal experience, so imo worth doing. Admittedly it was with a 540 though
9651 Posted May 17, 2012 Posted May 17, 2012 I would do a full power cycle, G2, can be a bit fussy with RKP's on a restart only
Zemme Posted May 19, 2012 Author Posted May 19, 2012 All your a conections should connect to a and all b to b. Have you exited engineer mode after adding the devices so the panel can find them? Hi Jameswilson, thank you very much for the reply. Yes, we exited engineers mode after adding the devices. Currently the A & B datalinks from the 2 keypads and the rf portal are connected in a Star to the A & B datalinks on the panel. The downstairs keypad is working fine as it was the primary connection the A & B datalink on the panel. So i can rule out that the RS485 is faulty on the databus. I also took the keypad upstairs local, bypassing all the structured cabling currently in place in the properties wall. The problem still remained. I also replaced the existing keypad for 2 brand new ones. So this ruled out a faulty keypad. Thanks for taking the time to reply, Appreciate it. Best Regards A line of *********s on the RKP = No Communication on A B Line, possibly faulty PCB Hi Magpye, , thank you very much for the reply. I spoke to Honeywell Customer Support. They advised that the issue is related to "No Communication on the A & B Line", as you kindly mentioned. I was advised to remove the Star connection & Daisy chain the connection instead. My Uncle will be coming over to rectify this today. Thanks for taking the time to reply, Appreciate it. Best Regards
Zemme Posted May 19, 2012 Author Posted May 19, 2012 Or lack of resistor Hi Fozzies, thank you very much for the reply. I spoke to a friend of a friend who is an ADT Alarm engineer. He gave me some advice, which did mention using a 680ohm resistor on the last peripheral between the A & B Datalink on the RF Portal. He advised me to daisy chain the 2 keypads and the RF portal, then on the RF portal to install a 680ohm resister on the A & B Datalink.My uncle will be trying this today. The RS485 databus is working fine, as the downstairs keypad is working fine. According to the Honeywell engineers manual it states to use a 680ohm resistor also & daisy chain also. I'm hoping this is proves correct. I have been to Maplin and purchased some 680ohm resistors as I misplaced the original ones that came with the panel. Thanks for taking the time to reply, Appreciate it. Best Regards Doubt its the resistor Also it will not communicate with the panel till the panel is aware its there. A power cycle or exiting engineers will instruct the panel to look for new devices added to the system Hi Jameswilson. I honestly think that the problem lies in the cabling fashion, i.e. that the Star fashion connection is incorrect & that it should be a Daisy Chain connection from each peripheral. I have power cycles the panel a few times & also exited the engineer mode. Thanks for taking the time to reply, Appreciate it. Best Regards
james.wilson Posted May 19, 2012 Posted May 19, 2012 Star isn't best but wouldn't stop it working imo. You have another issue I think What happens when you move the keypad that is working upstairs. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
