Problem With Programming Final Exit
Hi, I have installed a Honeywell galaxy g2-20 and am havin problems with the exit. I set it to 1001 final it counts down from 30 secs then sets but when I open the door , the system alarms showing intruder. Can anyone help please.
Yeah the door is definately 1001 final and the pit opp the door is exit which is 1002. On entry there is no entry countdown time displayed on the keypad which is set for 30 seconds and ten seconds exit. As soon as you open the door the it triggers the alarm immediately, checked through parameter 21 1001 works open and closed equals closed on shut, all pir's work open on detection. Just don't know what I'm doing wrong. Ps the resistance on door contact is 1k shut 2k open.
Thanks
  • 2 weeks later...
Make sure zone 1001 is programmed as final and it is the correct one obviously go to paramters and set exit time 000 the system should now set as normal when the door is closed, give it a try i am sure this has happend to me in the past on a G3 you dont get this problem
how are you setting XXX & A ?? have you reprog the A button for part/night set so the circuit is operating differently than the full set?
