Simon K Posted July 21, 2013 Author Posted July 21, 2013 Right, all of the DT-725D's have angled connectors like that, and at least one other isn't working correctly (30k ohms show up instead of 11k5, appears to be a bad connection on the tamper connector). I think I'm best off replacing them all. Please can anyone recommend a reasonable but inexpensive replacement? Ideally one that will have the same mounting so I don't have to drill new holes in the wall ;-) , -simon
james.wilson Posted July 21, 2013 Posted July 21, 2013 id stick with the honeywell units quite a good dt and priced ok. We used to use honeywell DT's but now use optex securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sjsturner Posted July 21, 2013 Posted July 21, 2013 id stick with the honeywell units quite a good dt and priced ok. We used to use honeywell DT's but now use optex Agreed. I have the honeywell dt's in my place, but use optex at work both are good.
Simon K Posted July 21, 2013 Author Posted July 21, 2013 Trouble is it seems you can't buy them any more (. What's the modern day equivalent?
james.wilson Posted July 21, 2013 Posted July 21, 2013 Dt7450 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted July 21, 2013 Posted July 21, 2013 Actually you did suggest the Risco Gardtec CPX - on page 2 of this topic, it was the only panel you suggested. I looked around for others which were also DEOL but couldn't find any, so bought the one suggested. That said, I'm fine with it - I just need something better than the Melcom which I can install myself. I'm even going to connect up its voice dialler (I have two phone lines at home, I'll leave the SD2 on one and connect this up to the second). So all said -- enough discussion of the panel, unless you guys really want to ) Now an actual DIY installation question. I have ripped out the old alarm and made good as much as I can the existing wiring, which was a horrible mess. There was no consistency on the colours used, so the tamper circuit was blues connected to oranges connected to greens, and the power was a multicoloured bunch. Not fun, and in addition it was an impossible mess, but now tidied up and made consistent. I have the new box on the wall with all wires fed through, and the wiring all connected for the bell-box, RKP, internal sounder and power. I'm now working on connecting up the zones, and installing the detectors one by one. Since EOL wiring is new to me, I put one of the detectors on individually to understand how it works. The detector is an Intellisense DT-725D (I have Five of these dual-tech ones and two simpler unbranded PIRs). I have given power to V+/V-, and I have blue on one Tamper, then a 4k7 connecting to alarm C, a 6k8 bridging alarm C to alarm NC, and green going back from alarm NC. I have my Fluke 87-5 connected to green and blue in the panel measuring resistance. When the tamper is good (cover closed), I see a constant 11k5 Ohms (well 11.493 but within tolerance), irrespective of whether the detector has detected movement or not. The detector is clearly working - the LED lights up when movement is detected - however the reading on the end of the cables doesn't change. I was expecting it to show 4k7 when the zone is secure (since the alarm connection should be closed), and 11k5 when the sensor triggers detection. Is that correct? What have I done wrong? -simon ok, read back i did mention the CPX - this was as an example, i did not actually suggest or recommend you to use it, as i don't know all your requirements (we have a duty of care, even for general advice), mentioning pabs later after you had ordered the CPX for example.11k5 is showing alarm, you have the tamper resistor in series with the contact bypass resistor, if the alarm contact is shorting the bypass resistor, you should only 'see' 4k7. perhaps you have not tested with resistance detector powered up and in ready state? or you have used the wrong side of the relay connection? If you think education is difficult, try being stupid!!!!
MrHappy Posted July 21, 2013 Posted July 21, 2013 ok, read back i did mention the CPX - this was as an example, i did not actually suggest or recommend you to use it, as i don't know all your requirements (we have a duty of care, even for general advice), mentioning pabs later after you had ordered the CPX for example. you peddle your Sinclair C5 backwards too ? 11k5 is showing alarm, you have the tamper resistor in series with the contact bypass resistor, if the alarm contact is shorting the bypass resistor, you should only 'see' 4k7. perhaps you have not tested with resistance detector powered up and in ready state? or you have used the wrong side of the relay connection? read the text & looking at the pictures I'd expect the clever money to be termial on the pir pcb are screwed ? Mr Veritas God
Simon K Posted July 21, 2013 Author Posted July 21, 2013 Turns out that the terminal was loose after being tiwsted out of shape. Pushing back into alignment causes correct behaviour on the bench, but was concerned that this was fragile so decided to resolder. A bitch to reach since the rear side of the PCB is shielded but repair done and detector works correctly, closing when power on and opening when alarm triggered. I have two left (out of seven total) which don't work. One appears to be a similar issue, but with tamper (doesn't react to tamper micro switch, circuit continually open) - will look and fix tomorrow. The second appears to be an issue with the cat5 - will probably use a spare pair tomorrow.
arfur mo Posted July 22, 2013 Posted July 22, 2013 did you not do the insulation and installation tests on the cables as i presscribed? Personally, for what they cost i'd replace the detector, might work a week, month 3 years with a idden fault, due to DOEL robustness - why risk if you have 'fixed it' for an old detector, how many others show this abuse, but are currently working? Its callled 'avoiding avoidable faults' and that often requires a good idea where the recycling bin us . If you think education is difficult, try being stupid!!!!
arfur mo Posted July 22, 2013 Posted July 22, 2013 Turns out that the terminal was loose after being tiwsted out of shape. Pushing back into alignment causes correct behaviour on the bench, but was concerned that this was fragile so decided to resolder. A bitch to reach since the rear side of the PCB is shielded but repair done and detector works correctly, closing when power on and opening when alarm triggered. I have two left (out of seven total) which don't work. One appears to be a similar issue, but with tamper (doesn't react to tamper micro switch, circuit continually open) - will look and fix tomorrow. The second appears to be an issue with the cat5 - will probably use a spare pair tomorrow. Peddles going backwards on a C5 it will break your leg, roll backwards it will blow up the controller . So wazzzup! You sore you did not consider to mention DOEL, and this one man band 'old fart' beat the yuppy e eveything Gal pack? If you think education is difficult, try being stupid!!!!
