ni3k Posted June 13, 2012 Posted June 13, 2012 Hi guys, recently moved into a new property with optima xm6 installed, i believe model number is - 8EP 395 Optima G3 panel with built-in keypad basically there is no response when pressing any buttons, is there some quick easy fix such as switching off the mains and removing battery? thanks
james.wilson Posted June 13, 2012 Posted June 13, 2012 you could try that, depends whats wrong with it. Before you do what lights are on the panel. It probably has a tamper or PA alarm still active on it which would cause it to appear un resposive. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
miaren Posted June 13, 2012 Posted June 13, 2012 Sounds like the tamper circuit needs to be restored, then it will wake up...
ni3k Posted June 14, 2012 Author Posted June 14, 2012 Just the power light on, I've been reading a lot about faulty battery needing replaced?
PeterJames Posted June 14, 2012 Posted June 14, 2012 Yep it may well be the battery, take a look at the back of the PCB if its black and the resistor is scorched its time for a new control panel, a new battery every four years would of saved this from happening
