squires Posted August 3, 2012 Posted August 3, 2012 a bullet for each cat would be preferential. made me chuckle this. i dont like pet sensors period. A movement sensor is designed to detect movement. I find it amusing that people expect such a cheap device (less than 20 quid) to be able in tech terms to tell the differencve between a person and a dog etc. They cant really. They are just slugged down normal pirs. The animal has a smaller IR output than a person. But if they get close to the sensor etc and move vertically then the sensor sees a larger IR trace. There is NO sensor that has passed 3rd party testing WHEN in any pet mode. There may be a reason for that! Best way to achieve alarm protection with an animal is to use perimeter protection, ie all external doors and windows where the pets are located when the alarm is armed. Normal sensors everywhere else I agree with the above ^^^^^^ only thing is cats tend to go where they want to
securityworld12 Posted September 16, 2012 Posted September 16, 2012 Pull the fuse on the fused spur feeding the pannel then remove the battery the most importantly check and label up all of the exsisting cables inside the pannel oh and disconnect the sab as it will be ringing and waking up the neighbours
