Sparky190 Posted June 29, 2012 Posted June 29, 2012 I have recently installed a door entry system, but the lock does not seem to function properly. It is a acet 66266 2 wire system, but using original door lock. The intercom works fine, but when you try to buzz in the door does a half click and does not release the catch completly Any help would be much appreciated. Scott.
Sparky190 Posted June 30, 2012 Author Posted June 30, 2012 I have 12v dc at the hand set, door catch and intercom. Everything switches over when it should do. Could it be a case of not enough voltage from handset to door catch, as when i link the feed and door catch out at the intercom system the door catch operates fine? .
Cubit Posted June 30, 2012 Posted June 30, 2012 But what about the lock? What's that rated at or set for?
