Texecom 24 Premier - Chime Whilst Alarm Set?
Not sure what you mean there James.
Six, ET on the TS and M still chimes when set IIRC so it would be a perfect way of doing this,
However as you state there are differences and I will bow to your better knowledge of the Premier. Although having worked on them I have not had the need to do as suggested.
My point was there wasn't another way on a TS.
On a Premier however Custom is the best way not ET. This is because it will not kill the E/E timer if the "chime door" was to change state while arming.
The Door will be purely for chime and has no way of causing any issues, unless the Warning or other Sub-Attributes are enabled as above.
I am guessing James means the Meniver lads that moved have moved on again...?
Yes I know the TS was limited that way.
Custom sounds good, although not read that part of the book of words yet.
I thought Mark was still there, I`m sure Adrian mentioned him when we last chatted. Perhaps I was mistaken but it was a while ago now.
