aetherica Posted August 19, 2012 Posted August 19, 2012 Your idea about "Baluns" is correct in a Cat5 cable using two cameras but NOT the coaxial mentioned above. "Hearing" about something is different to actually knowing and giving actual advise. As above Google "Duo link" "2 Cameras one coax" Thanks for the correction. We have never used Balun, but our distributor has told us about it. And yes, you are right that it uses Cat5 cable. --------- CCTV Aetherica - Surveillance & Security Solutions ---------
