MISHPET Posted July 10, 2012 Posted July 10, 2012 Hi can anybody help we have an alien dvr eco with 4 cameras based at the office, which up until recently we could view on iphone/ipad at home. Suddenly for no appparent reason i can see all cameras when in the office and when in office we can see from iphone or ipad so long as I change the ip address to match the dvr one but the ip seems to have changed from our static ip address .But at home it says device login failed dvr network connect failed on either ip address. Am not sure how to rectify this any help would be appreciated Michelle
james.wilson Posted July 10, 2012 Posted July 10, 2012 Are you definetly on a static IP? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MISHPET Posted July 10, 2012 Author Posted July 10, 2012 yes we are the ip address is 81.136.136.174 which comes up every time you ask whats my ip although the one ip address the dvr has turned itself to is 192.168.1.64. If you type in the 81 address into the computer attached to dvr it cannot find it.
james.wilson Posted July 10, 2012 Posted July 10, 2012 Your wan address will not work locally unless you have set this up in your network. Most routers cannot handle what you want from the internal network. You should use the 192.168.1.64 address when on the local lan and the 81.x.x.x address when remote. Is the dvr IP address static too, ie the 192.168 address. If that is assigned via DHCP that will affect your port forwards if the address changes. Best way is to use DHCP and reserve the address of the dvr in the dhcp server or use static address in the dvr. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MISHPET Posted July 10, 2012 Author Posted July 10, 2012 James Thanks for your quick replies, tho I must confess I am a bit of a dummy where this is concerned so could you explain how would I go about doing what you suggested.
james.wilson Posted July 10, 2012 Posted July 10, 2012 How is your dvr currently addressed? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MISHPET Posted July 10, 2012 Author Posted July 10, 2012 The computer in the office which shows the images has the ip starting 192. In the address bar.
james.wilson Posted July 10, 2012 Posted July 10, 2012 Ok, but your dvr. It will either be set to a static IP address in the DVR setup or it will be set to DHCP. Which was is the dvr setup? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
MISHPET Posted July 10, 2012 Author Posted July 10, 2012 Mmm not sure I didn't set it up and am at home now but the guy that set it up did say we must have a static ip address I can check in the morning when I go in and get back to you how do I check Sorry to be a pain
james.wilson Posted July 10, 2012 Posted July 10, 2012 There are 2 different tings here MISHPET I think you are talking about your external Static IP address, ie your public internet address or WAN address. Im assuming you have that (its your 81.x.x.x address) You then port forward in your router to your dvr (on the 192.x.x.x address) But if the dvr is changing its address on the internal network the port forwards will fail as the router will be forwarding to the wrong internal address. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
